Home › Forums › Product Discussion & Questions › BeoRemote › Connecting an Essence remote with Beosound 5 Encore
- This topic has 3 replies, 2 voices, and was last updated 3 years, 12 months ago by
sakis_s.
19 April 2022 at 07:36 #34250
sakis_s
BRONZE MemberHas anyone tried to connect an Essence remote with a BeoSound 5 Encore system?
19 April 2022 at 17:42 #34251 MillemisBRONZE MemberThe BS Encore is an ir-controlled products.
Be sure that the Essence remote supports ir modes (the first versions did not).
Then switch it to ir mode – see here:
Maybe this can help:
This is all I can find right now – maybe another member knows more.
20 April 2022 at 08:57 #34252 MillemisBRONZE MemberSeems that not all can see the pic/screenshot, that I postet previously.
Tried to convert (from png) to jpg – maybe that is better.
20 April 2022 at 09:55 #34253sakis_s
BRONZE MemberThank you so much for your reply.
Do you know how to stand out the first versions of the remote with the later versions?
Is there any specific characteristic that you can see by looking at the remote to understand the different version? -
