Home › Forums › General Discussion & Questions › General Discussion & Questions › Connecting a BeoMaster 5500 to a Beolab 2 subwoofer and Beolab 3 speakers
- This topic has 2 replies, 2 voices, and was last updated 1 hour, 29 minutes ago by
Chris Williams.
10 April 2026 at 00:24 #123247
Chris Williams
BRONZE MemberHi, I’m going through a bunch of B&O equipment. We have a BeoSound 9000 CD Tower hooked up to a pair of beolab 9 speakers, as well as a Beogram 5500 turntable and a Beocord 5500 cassette deck.
All that’s working, my problem is getting the Beomaster 5500 which uses an earlier generation sound connector to hook up to the Beolab 2 subwoofer (and from then on to Beolab 3 speakers.) I have the cables to go from the subwoofers to the speakers.
I’ve Been told I need a seven pin to eight pin DIN cable. Where can I obtain one, and will it work?
Any help will be appreciated, thank you so much.
You must be logged in to view attached files.10 April 2026 at 12:54 #123254 AdamSBRONZE Member10 April 2026 at 17:16 #123255Chris Williams
BRONZE MemberI checked his website, and he was shut down for the holiday. Is there a source in the United States, where I’m located?
Alternatively, I make most of my own cables, so if someone had a pinout, I could source the DIN connectors locally and make the cable I need.
This reply was modified 1 hour, 28 minutes ago by
Chris Williams.
This reply was modified 1 hour, 24 minutes ago by
Chris Williams.
