Home › Forums › Product Discussion & Questions › BeoMaster › Connect with Mac to BeoMaster 5
- This topic has 2 replies, 2 voices, and was last updated 2 years ago by
griebel.
23 March 2024 at 05:24 #53752
griebel
GOLD MemberHi,
I have done this many times…. but not recently.
Can anyone remind me how to connect a Mac to BeoMaster 5 to access the media files?
I used the command smb://ip address of the BM5/bm-share$; then entered the username BM-USER and my password. Unfortunately, it doesn’t work.
Update: I could make it work by re-entering the password in BeoSound5. A bit weird.
Guy
23 March 2024 at 18:44 #53753XavierItzmann
BRONZE MemberOn Finder: ⌘-K
or Finder > Go > Connect to server…You should get a dialog:
Enter your password. Mine is very, very long and of course unique to this device.
If you enter the correct password, a folder will open up:
24 March 2024 at 12:11 #53754griebel
GOLD MemberThanks!I actually solved the issue by re-entering the password in BS5. Must have gotten lost since I last connected quite some time ago.
