Home › Forums › Product Discussion & Questions › BeoCenter › Connect Beocenter 4600 to Theatre
- This topic has 1 reply, 2 voices, and was last updated 9 months ago by
Peter Fraser.
28 May 2025 at 10:39 #65863
Ben Spijker
BRONZE MemberQuestion Recently I have bought a B&O theatre, an excellent device. I have also a Beocenter 4600 from the year 1978, which was bought by my parents. Which plays as new. Now my B&O dealer had connected those devices. The problem is that when I play a LP the must be the soundlevel on the Theatre sky high to get some music and by the low noise level there is a very bad low frequency hum. Question is there a solution for this problem. Please your advise. 26 June 2025 at 13:54 #66671Peter Fraser
ModeratorHello Ben,
When you play a cassette or listen to the radio on the BeoCenter 4600, is the audio still low?
You can adjust the Line-in sensitivity within the Bang and Olufsen app.
How can I use Line-in on Beosound/Beovision Theatre? – Bang & Olufsen SupportHow are you getting the sound from the BeoCenter 4600 to the Theatre?
Kind regards,
PeteSignature: Peter Fraser
Service Technician
Multicare Electronics -
