Home › Forums › Product Discussion & Questions › BeoCord › Changing Beocord 7000 belts
- This topic has 1 reply, 2 voices, and was last updated 1 year, 11 months ago by
anthony elliot.
3 January 2023 at 05:42 #42085
GraceF9
BRONZE MemberI need to change the main belt on my beocord 7000, and I need help!
I have in the past successfully changed belts on my 5000 and 5500, and there are subtle differences on the 7000. I have got to the stage of accessing the main tape unit, (thus being able to change the first belt), I have discovered how to remove the black plastic casing (thus being able to change the small belt), but I am absolutely stuck how to dismantle the unit further to change next belt (the large flat one). This was very easy on the 5xxx, but I cannot see where even to start on the 7000. Any advice would be gratefully received.
8 May 2024 at 11:01 #55379anthony elliot
BRONZE MemberHi GraceF9,
I have the same issue, did you find out anything?
Regards
Tony
