Home › Forums › Product Discussion & Questions › BeoGram › CDX 2 Repair , almost there..
- This topic has 6 replies, 3 voices, and was last updated 2 years, 9 months ago by
jbh2.
8 June 2023 at 09:49 #47069
jbh2
BRONZE MemberHi.
New gear and belt for the lid, and its nearly OK.
Only problem is when lid close, it makes a little “jump” 2-3 mm, then closes fully.I changed the blue cap. on the motor control pcb 8. It was 20 uF so I changed it to
the right one 68 uF. But that was not good. When lid opens fully it makes a bad “krak.krak” sound. Gave it the old 20 uF then, opens fine witout krak sound.
Does anyone have a tip with the small jump at closing ?
Br Jens
10 June 2023 at 15:00 #47070quattttro
BRONZE MemberHow’s the plastic standoff that holds the lid/motor gear shaft? Mine was cracked quite badly.
12 June 2023 at 08:45 #47071jbh2
BRONZE Memberproblem solved. By lubricating the belt with a little grease and reduce the friction
it works now. Opens and lid stops at top without crakking.
12 June 2023 at 21:43 #47072Dillen
ModeratorLubricating the belt?
Sounds more like an adjustment issue with the lid switch.Martin
15 June 2023 at 07:16 #47073jbh2
BRONZE MemberHi Martin, thank you for answer. (er du ikke dansk, syntes jeg har set Dillen navnet før ?)
I cant see how LID adjustment is possible, the lid switch is mounted with 2 small screws and it have very little tolerance in holes. I have tried to adjust.
Also the LOAD switch is with 2 screws.
I have seen that its possible in a CDX to adjust LOAD and LASER sw.
There is no LASER sw in a CDX 2 and no MAINS sw,
I need the schematic for a CDX 2, have only one for CDX.
In a CDX the LID motor UP/DOWN voltage must bee +5 volt and -5 volt.
But I have +8 volt and – 5 volt so maybe the +8 volt is too high at makes the crack sound ?Mvh Jens
15 June 2023 at 12:51 #47074Dillen
ModeratorBeogram CDX2 has more in common with Beogram CD3300 than CDX.
For some of the Beogram CDX2 circuits, you can use the CD3300 service manual.Martin
21 June 2023 at 09:14 #47075jbh2
BRONZE MemberThank you. I found the 3300 service manual and the schematic. Almost the same as in CDX 2.
The problem was the (too high) positive voltage to motor. ( LID up.) It was 8 volt.
I could not find any defective components, so I added a 15 ohm in series with the collector on the driver transistor to motor. Now it opens very smoothly.The minus -5 volt was -4,4 v so that worked fine. ( LID down.)
