Home › Forums › Product Discussion & Questions › Other › CDM12.4 for a VAU1255
- This topic has 7 replies, 5 voices, and was last updated 2 years, 6 months ago by
kronzilla.
26 June 2023 at 08:57 #47397
Pindsen
BRONZE MemberHi,
Where in Europe is it possible to order a CDM12.4 for a VAU1255 used in a Beosound 3000?
My normal “supplier” in Germany is out of stock, other times I have ordered from China (with good luck) but after the recent tax on goods into Europe the postal service in Denmark charge around 160 DKK extra now so it could be good with a new “supplier” in Europe./Pindsen
27 June 2023 at 12:13 #47398 filip_kbhBRONZE MemberWhy not just clean the lens from both sides. Look up the thread about fixing laser on Beosound 9000. There’s a video that shows how to do it.
27 June 2023 at 20:05 #47399Pindsen
BRONZE MemberI have tried that without no luck.
27 June 2023 at 20:46 #47400 matadorModeratorThe mirror too ?
28 June 2023 at 19:00 #47401Pindsen
BRONZE MemberYes, both side of the lens and also the mirror down in the “channel”. It is a new laser I need.
28 June 2023 at 19:10 #47402 matadorModeratorZut, not a good news, I used to believe the deep cleaning was a forever cure.
I remember it was a thread on the old forum about, I don’t know, reflowing some connections or maybe replacing one or to capacitors, in a nutshell another path out from the usual “just replace the lens”.
I WANT to believe that lasers last forever and ore not just 5 years life long components.
29 June 2023 at 19:54 #47403 chartzBRONZE MemberLook, I have quite a few CD players, some 40 years old, and they almost all still work. I’ve yet to find a Philips-based player that isn’t fixable, by the way. All my B&O CD players have their original laser assemblies.
However, the CDM12 don’t seem as reliable, although mine all work perfectly.
30 July 2023 at 22:32 #47404kronzilla
BRONZE MemberHello Pindsen. The lasers in the cd-pro and cdm12 and vau are only lasting 6k hours. So you want to replace the laser in the CD-pro module. (The swing arm lasers in older music systems are lasting 60k hours so ten times as much )
You can send me a pm and i could order a laser for you, i’m living in Belgium. Can send it to you then? Did you replaced a laser in a CD-pro module? You need to be precautious, so wearing an esd wristband and using an antistatic mat, to prevent damage to the dac board or the laser…
