Home › Forums › Product Discussion & Questions › BeoGram › CD3300 high pitched squeal at the outer tracks during play, radial servo noise??
  • #125460
    Garten47
    Hi all,
    Have a Cd3300, needed the usual CDM recap, ordered the capkit from Martin, all sorted, plays beautifully, tracks found  quick, like new!
    BUT, it has now developed a high pitched squeal when jumping to and reading from the outer tracks, its loud enough to be quite disturbing.
    It sounds like some players that develop a quite pronounced squeal when seeking track, but much more pronounced, and I then have that continuously during play, but only at the outer tracks…
    Like if the CD has 24 tracks is on 22,23,24.
    So i narrowed it down to the radial servo, , but cant understand why all of a sudden,… Some people talk about possible sagging of the mechanism, but the laser assembly moves very freely, so no mechanical issue seems to be present.. tried shimmy the disc, but no difference.
    I have not adjusted or changed anything, just changed the caps and put it all together again, and it reads everything, burned cd-r, scratched discs, juast aslong as it not in the outer section…
    Any thoughts?
    Any test I can do to undestand what is going on, does something need lube?, but how could this have happend just by turning the unit upside down a couple of times? (tried to turn it upside down again a few times, but nothing changed)
    By the way, i have worked on these and the cd4500 and cdX before, but this fault is new !! :=)
    Thanks all
    #125461
    Garten47
    …After some additional analysis, there seems to be a heat/time component.
    When the player has been switched on and playing “for a while” the high pitched noise goes away playing those end of disc tracks.
    I also lifted the player and gently angled it in different tilts, that did not lessen, change or remove the squealing.
    so something heats up and expands? or something heats up and becomes less viscous?
    Thanks!
    #125496
    Garten47
    It was not heat dependent, I was mistaken, i measured the frequency its spot on 5168Hz, all the time….
    Does this bare any significance?
    thanks
    #125782
    Dillen
    Perhaps someone messed with the laser current (and focus offset if present) adjustments.
    I see this often when desperate owners or untrained service people panic to get the thing going (instead of merely replacing the servo board capacitors).
