Home Forums Product Discussion & Questions BeoGram Cartridge MMC 5000 for Beogram 4000?
  • #70373
    Yvan Janin
    Hello there,
    Does anyone can give me more information about the following cartridges:
    – MMC 5000
    – SMMC20E
    My Beogram 4000 has been repaired,  the cartridge replaced with a Soundsmith SMMC20E.
    I once bought for a good price an original B&O MMC20E. I unfortunately then thought it was lost, so I have much later bought a B&O MMC 5000 to replace it. The seller told me it was compatible with my Beogram. But I now doubt it…
    Does an expert or anyone who knows very well this concern can help me?
    By chance I found the MMC20E, so now I have two cartridges in reserve. Maybe, depending on your answer, I can sell the MMC 5000 to anyone interested.
    Thank you.
    #70374
    Mark-sf
    The MMC5000 has a Shibata-shaped stylus designed to support CD4 records. It has a much narrower profile than the 20E family which is elliptical. Assuming its suspension has not dried out since it was released in the late 70’s (an optimistic assumption) and is not worn out, it is technically compatible. What makes you think it is not?
    #70402
    Yvan Janin
    Thank you, though it sounds too technical to me.  I absolutely do not know anything in it. I couldn’t find on the net if it was compatible and both are so expensive today.
    Both are carefully put in a box provided for this purpose.
    #70407
    Mark-sf
    No problem. Putting it more simply, while the cartridges are compatible they wear out due to use and go bad due to the rubber-type parts aging even if stored in their original box. Unless you purchased them new, you can’t know how many hours of playing time they’ve had. With care your 20E will last up to 800 hrs, and the 5000 to 1000. Only a good microscope can evaluate. A test record can evaluate the rubber suspension state. Be advised a worn out cartridge will damage records. A quality dealer or retipping company can evaluate.
