Home › Forums › Product Discussion & Questions › BeoVision › Can not change channel using BROne and BV11
- This topic has 7 replies, 4 voices, and was last updated 3 years, 2 months ago by
Hiort.
3 January 2023 at 09:30 #42068
HiortGOLD MemberI have my Beosound 1 integrated with my Beovision 11.
If I press RADIO on my Beoremote One (IR version), I get Tunein playing on the BV11 from the BS1 Tunein source. So far all good.I recall that I used to be able to change Tunein channel with the remote, but does not work now. No matter what button I press. Only volume works when playing Tunein.
Is that something that have changed?
/C
3 January 2023 at 11:04 #42069 carolpaBRONZE MemberI just joined the BV11 to the Beoplay 6.
Playing (dlna) music I could skip to the next and previous track with a BR1 (ir).
Although I do not use TuneIn anymore, skipping between radio stations on B&o Radio worked with the BR1.
Note: the BP6 is not integrated with the BV11.
3 January 2023 at 11:06 #42070 TignumGOLD MemberHello Hiort, sounds like the same issue that Rolf2 and I have, see here: https://forum.beoworld.org/forums/topic/bo-radio-migration-available-now/page/4/#post-12269.
We found that after changing station once in the app, then changing stations with the remote works as normal again.
Regards, Johan
3 January 2023 at 13:44 #42071 HiortGOLD MemberHello Hiort, sounds like the same issue that Rolf2 and I have, see here: https://forum.beoworld.org/forums/topic/bo-radio-migration-available-now/page/4/#post-12269.
Regards, Johan
Thanks Johan!
That worked for me as well. The drawback is that the Beosound 1 the goes from mute to playing. I have submitted the question to B&O support. I will revert back in this thread with what they say.Location: Sweden
3 January 2023 at 14:16 #42072 HiortGOLD MemberShall add that if I put everything in stand at and then start up again it does not work to change channel again.
7 January 2023 at 18:19 #42073 HiortGOLD MemberUpdate: B&O support informed me that an update was triggered for my BS1 to cure the problem. 2.1.51694 is now in BS1 and I can change channel as I used before ?
7 January 2023 at 19:28 #42074 MillemisBRONZE Member@Hiort
Was that an update just for your BS1 or is it a general one?MM
7 January 2023 at 22:42 #42075 -
