Home › Forums › Product Discussion & Questions › BeoVox › Can I use Beovox Cona with Beovision 7?
- This topic has 5 replies, 2 voices, and was last updated 1 year, 3 months ago by
Madskp.
8 December 2024 at 17:29 #61440
CharlieWednesdayGOLD MemberI have just got hold of a Beovox Cona for a very low price on eBay (it was local collection, only cost £30 so I thought I might as well).
I have a full set of front/rear/centre speakers connected to my Beovision 7, but I don’t have a subwoofer. I know that the BV7 expects an active subwoofer, but I thought I might be able to get it to work with the Beolab Passive amp that I already had, as it was not in use elsewhere.
The Beolink Passive amp has a Powerlink socket, but the guide says nothing about it. I connected the Subwoofer output of my BV7 to the Beolink Passive via Powerlink, then connected the BV Cona to the speaker outputs of the BL Passive amp. I went into the settings in my BV7 and switched the Subwoofer option to ‘Yes’ in settings.
Nothing is happening though – no sound from the BV Cona. Does anyone know of a way to get this working?
8 December 2024 at 18:49 #61441Madskp
GOLD MemberYou will need a fully wired POwerlink cable for the Beolink passive to be activated by the BV7.
I actually used a Cona this way for a BV8 and maybe also for a short while with my Beoplay V1, so it is fully possible.
Wheether there are some sound wise things like frequensies that is not right I am not able to tell.
8 December 2024 at 18:54 #61442 CharlieWednesdayGOLD MemberI’m not sure what you mean by ‘fully wired’ Madskp? I tested it using a Powerlink Mk3 cable. Would Mk2 cables be what you describe as ‘fully wired’?
8 December 2024 at 19:18 #61443Madskp
GOLD MemberYes the MK2 is usually fully wired. For testing you can also use a 7 pin audio aux cable
8 December 2024 at 19:33 #61444 CharlieWednesdayGOLD MemberAh – I happen to have a 7-pin audio aux cable going spare, so I have connected that, and it’s working!
I’m not really sure what to expect as I’ve never owned a dedicated subwoofer before, but you can certainly feel that bass from it.
My Beolab Penta Mk3 speakers do suffer a little when playing modern music which has heavy sub-bass – the bass can be a bit distorted and flat, so hopefully with a bit of tinkering with the bass levels, I might be able to get some good bass from the Cona instead. My Pentas could probably do with a professional service really.
Thanks for your help Madskp, as always.
8 December 2024 at 19:45 #61445Madskp
GOLD MemberGlad to help, and great that it worked 😀
