Home › Forums › Product Discussion & Questions › BeoGram › Can anyone recommend a tracking force gauge?
- This topic has 2 replies, 2 voices, and was last updated 1 year, 7 months ago by
CharlieWednesday.
21 August 2024 at 16:13 #58507
CharlieWednesdayGOLD MemberI have three Beogram turntables and I’ve been having trouble with one of my MMC4s. I wanted to check the tracking force is right, so I bought a tracking force gauge.
the one I bought (here) is no good though – because two of my Beograms are linear and therefore have very little clearance beneath the stylus, this gauge is too bulky to fit beneath those. It works for my Beogram RX-2 as that has a standard arm, but it will not work on my Beogram 3000 or 8500, because they both have the linear arm with the low clearance.
Hard to tell from photographs online which would work best. It doesn’t necessarily have to be a digital one, just anything that would work, and not too expensive! Does anyone have any recommendations?
21 August 2024 at 17:49 #58514 Mark-sfBRONZE MemberYou can get that one to work by removing the top platter and belt.
21 August 2024 at 19:05 #58515 CharlieWednesdayGOLD MemberThanks – I was able to remove just the top platter and didn’t need to remove the belt or wheel- that did provide sufficient space to measure the stylus pressure. Turns out it was spot-on, but I’m glad I was able to check it!
