Home › Forums › Product Discussion & Questions › BeoLab › BV7 and Beolab 3500…
- This topic has 3 replies, 3 voices, and was last updated 3 years, 9 months ago by
carolpa.
7 June 2022 at 08:57 #35363
matadorModeratorHi alls,
Just out of curiosity, can a Beolab 3500 serve as sound bar for a Beovision 7?
I don’t know if it make sense and quite sure it won’t be pretty but Id like to know if it could work by itself without converter.
Thanks.
7 June 2022 at 10:02 #35364 Steve at Sounds HeavenlyGOLD MemberHi Matador,
In theory, yes this could work, as long as you don’t have any other speakers. However, it isn’t ideal and I would suggest that there are much better options such as Beolab 7-1, 7-2 or 7-6 depending on the TV screen size.
Beolab 3500 is a very poor performer compared to other Beolab speakers of its era, with little bass output and treble that isn’t optimal for TV dialogue. Connection would be via Masterlink, so the speaker would only get a stereo downmix (not true front or centre channels). Control would rely on both the TV and the speaker receiving remote control signals at the same time, so some issues may arise when trying to operate it, change volume, etc.
Hope this helps!
Kind regards, Steve.
7 June 2022 at 10:11 #35365 matadorModeratorThank you Steve,
Perfect comprehensive answer.
Regards, M.
7 June 2022 at 11:51 #35366 carolpaBRONZE MemberControl would rely on both the TV and the speaker receiving remote control signals at the same time, so some issues may arise when trying to operate it, change volume, etc. Hope this helps! Kind regards, Steve.
if both response to the same remote it will (sometimes) become a mess.
Example: command next channel will be received twice. So not the next channel, but the channel there after will be activated! Etcetera….
The way out would be to put one in option 4. But still not the easiest way to control both.
