Home Forums General Discussion & Questions General Discussion & Questions BV11-46 – add motor to wall bracket – possible ?
  • #70728
    Ravsted
    Got a BV11-46.
    Wall mounted – left side.
    It has been fine for long as the seating position was straight in front of the TV.
    But that changed … So a motorized wall bracket would be really nice.
    I see motors for sale. Can they be retrofitted on the non-motorised wall bracket ?
    As our house is 200+ years old and the brick walls are a bit sturdy I really don’t want to completely replace the whole wall bracket if I can avoid it.
    Regards
    R.
    • This topic was modified 1 day, 18 hours ago by Ravsted.
    #70730
    vikinguk
    Yes, on the similar BV11-40 the hinge motor is a simple plug-in to add to the hinge.
    Graham
    • This reply was modified 1 day, 16 hours ago by vikinguk.
    #70733
    Ravsted
    Alright.. so that means that this ‘part’ is just an empty ‘shell’ on the non-motorised version ?
    #70739
    vikinguk
    No idea about the empty shell. I do know that my son bought the motor and was able to fit it to his hinge. The approved B& O seller on this site has a motor for sale. Why don’t you ask them?
    Graham
