Home › Forums › General Discussion & Questions › General Discussion & Questions › BV Avant 75NG satellite signal software problem
- This topic has 2 replies, 1 voice, and was last updated 10 months, 1 week ago by
ekw.
23 March 2025 at 17:27 #64641
ekw
BRONZE MemberDear All!
My BV Avant 75NG shows strange behavior: it “looses” the satellite signal showing “no signal” (and of course black screen); if I do a hard reset (unplug) all the channels are back as if nothing happened; first I tried to redo the antenna but I think this behavior is due to a software issue which also might be connected to missing updates (android/google).
I was already thinking to reset the TV but than I get the even older software
does anyone have an idea how this issue could be solved?
My BV14 (should be the same software?) is running smoothly
best regards
Elmar
28 December 2025 at 12:57 #72138ekw
I was thinking, that the CI Module made the problems – now my BV14 shows the same issue; but unfortunately I need to accept, that is looks like to be a failing internal B&O satellite receiver; now I am looking for a third party product which is “PUC-capable” and has a CI+ slot (i need CI+ module to watch ORF).
please give some advice (no need of high end sat receivers).
Thanks, marry Christmas and a Happy New Year
Elmar
28 December 2025 at 12:58 #72139ekw
BRONZE Member -
