Home › Forums › Product Discussion & Questions › BeoVision › BV 11-40 mk4 turned black
- This topic has 2 replies, 2 voices, and was last updated 3 years, 7 months ago by
master123456789.
29 August 2022 at 05:25 #38648
master123456789
BRONZE MemberHi forum
My Beovision 11-40 mk4 suddently one night turned black. I was using the build in Youtube-app.
The sound is still there when I use the tv-tuner. Also when I turn on the television (when there normally is “Bang and Olufsen”) there are light in the screen. You can see the backlight at the screen as I understand it. Anyone who know what to do or is it just trash?3 September 2022 at 21:59 #38649bigbruggsy
BRONZE MemberHi, I have the same problem with my Beoplay V1-40 which is basically the same TV just in a different skin. Did you find out what the problem was with your TV?
4 September 2022 at 16:27 #38650master123456789
BRONZE Memberif you have the MK1 of V1-40 it is a very troubled tv. The BV11 is more stable. But no, I did not found out. Wating for someone in here to answer. My lokal B&O repair is sure too expensive.
