Home › Forums › General Discussion & Questions › General Discussion & Questions › BV 10-40 noise
- This topic has 1 reply, 2 voices, and was last updated 3 months ago by
Tignum.
29 November 2025 at 21:26 #71586
ruwiGOLD MemberHi
My latest acquisition is the BV 10-40. It is a great piece of workmanship, but the noise of the cooling fan is annoying. Is it really necessary to run all the time? Can I switch it off , and how?
Thank you for your suggestions.
30 November 2025 at 07:38 #71591 TignumGOLD MemberHello Ruwi,
That can be annoying! I did once replace the fan in a BV6 which helped a lot (they are standard computer fans). The fans are there for a reason I would say.
The BV10 has fan settings in the service menu. The Service Menu is activated in the following way:
The Service Menu must be activated while the TV SETUP menu is displayed.
Beo4: the Service Menu is activated by pressing 0 0 GO within 3 s.
Maybe you can play a bit with the settings. I would take a photograph of the standard settings.
Let us know how you get on!
Regards, Johan
