Home › Forums › Product Discussion & Questions › BeoSound › BS9000 MK I – power PCB schematic
- This topic has 4 replies, 2 voices, and was last updated 3 years, 4 months ago by
kordina.
4 November 2022 at 03:17 #40504
kordina
BRONZE MemberHi guys,
I have a problem with my MK 1 and unfortunately the site service manual is not complete. Does anyone of you have the schematic relating to the power board? It´s the circuitry relating to the voltage generation around the LM3578 (there are at least 4). Unfortunately the MK2 and 3 are completely different thus I cannot use those manuals as help.
Regards,
Staffan
7 November 2022 at 16:54 #40505 Keith SaundersBRONZE MemberStaffan,
Apologies for the late reply.
As the BeoSound 9000 Mark 1 manual is about 2 cm thick I just scanned the power supply section which is below and attached in a PDF. Click on the image to see it in large format.
7 November 2022 at 17:39 #40506kordina
BRONZE MemberExcellent Keith! This is the schematic I need! Would it be possible to copy the related PCB to allow me identifying the components on the board?
Many thanks in advance!
Staffan
13 November 2022 at 14:54 #40507kordina
BRONZE MemberHi,
If I wasn´t clear enough, the service manual also show the layout of the boards. I would need a copy of the Power Board layout to clearly identify the components in the schematic 🙂
Luckily I have a working Beosystem 6000 which is doing it´s service of entertaining us 🙂
Regards,
Staffan
13 November 2022 at 17:48 #40508kordina
BRONZE MemberSorry my mistake Keith. I checked my data again and found the PCB layout I needed.
Regards,
Staffan
