Home › Forums › General Discussion & Questions › General Discussion & Questions › Bs 9000 Minimum Softwarerelease to connect to NL/ml converter
- This topic has 2 replies, 3 voices, and was last updated 1 year, 2 months ago by
Peter Vaessen.
17 January 2025 at 14:50 #62826
Horst Schneider
BRONZE MemberHello,
What is the minimum software version that the Bs 9000 (mk2) needs to have in order to run satisfactorily in a setup of bv11 + converter? I’m actually only interested in controlling the CD part, the rest runs via the bv11 anyway.
I would also be interested in how the software releases differ.
Greetings horst
18 January 2025 at 05:46 #62849 carolpaBRONZE MemberHello, What is the minimum software version that the Bs 9000 (mk2) needs to have in order to run satisfactorily in a setup of bv11 + converter? I’m actually only interested in controlling the CD part, the rest runs via the bv11 anyway. I would also be interested in how the software releases differ. Greetings horst
The BV11 – BLC – BS9000 system setup is dependant on the setup of the BLC and not so of the sw version of the BS9000, thus no minimum sw nessacery.
24 January 2025 at 16:53 #63054Peter Vaessen
BRONZE MemberCarolpa is the expert on this!
Using a BLC is actually a great workaround for the BS9000 N.RADIO/N.MUSIC older software software problem. It will makes those sources individually accessable.
See for example https://forum.beoworld.org/forums/topic/making-bs9000-cd-source-accessible-with-beolink-converter-nl-ml-blc-2/
