Viewing 1 post (of 1 total)
  • #100068
    IR_peter
    Hi all,
    I had been a B&O fan in the past, and part of BeoWorld many years ago… But just came back now after many years….
    For one of my projects, I am considering creating a B&O IR gateway (ie get 455 KHz IR commands from BROne IR/Beo4/Essence Remote IR, and convert them to web APIs/MQTT, etc). I looked around and did not find anything solid (there used to be the Lintronic in the past, but I dont see it being available anymore.
    I was wondering, are there any interesting use cases, scenarios that this forum would see a need for such a gateway? Or other relevant functionalities for solving real world problems out there?
    (IR is the need I have, it could as well be BT).
    Happy to hear your thoughts… What problems do you have, and how have you solved them, in this domain? Thanks
    Peter
