Home › Forums › General Discussion & Questions › B&O Inspired Amplifier
- This topic has 11 replies, 5 voices, and was last updated 3 weeks, 2 days ago by
xschop.
11 February 2024 at 06:45 #52716
Hello all, new member here. Just thought I’d share my B&O-inspired aesthetic designed amplifier case. It has a large 190 mm integrated volume potentiometer and acts as a heat sink with lower convection cooling. I recently rebuilt and modified a set of CX100’s and connected them in parallel to a passive subwoofer. After their rebuild, I was taken aback by the enormous soundstage and overall presentation, that I had to design an amplifier case to match the aesthetics that B&O is known for….
11 February 2024 at 22:06 #52717That is an impressive job! And certainly not a usual shape for an amplifier. Regards, J.
Location: NetherlandsMy B&O Icons:11 February 2024 at 23:26 #52718Great work there. Very neat and clean looking.
21 February 2024 at 13:37 #52719Thank you. I look forward to building another one.
21 February 2024 at 14:05 #52720That looks superb – excellent job!
Although I hate to break it to you but you’re not really listening to CX100s by the looks of it, as they appear to be far from original.
21 February 2024 at 17:25 #52721I’ve owned quite a few classic Beovox and I have to say these are the best imaging and midrange-detailed for their size. I have another set that I will do the exact same modifications to. I have built custom baffles out of solid alloy and it is the go-to medium in my opinion.
Again, kudos to B&O for the quality of alloy they used in making these back in the day. They simply need a layer of dampening applied internally to make them almost dead-quiet.
14 December 2024 at 01:25 #61592Thought I’d share my latest B&O inspired amp based on the TPA-3251 chip amp…
15 December 2024 at 10:24 #61636Built to last! Beautiful work xschop.
Location: NetherlandsMy B&O Icons:9 January 2025 at 20:04 #62469Built to last! Beautiful work xschop.
Thank you Tig. I usually don’t build anything unless it is “nukeproof”.
I’m taking the design further and adding balanced inputs with another TPA3255 with PFFB. One of the best sounding amps I’ve heard to date.
29 January 2025 at 13:10 #631892 February 2025 at 09:52 #63306Wonderful work.
Now you need to visit a shop with a Laser engraver to add the last bit of perfection 😉
17 February 2025 at 00:30 #63841Started building another one. Incorporated heat dissipation ribs around circumference near bottom heat plate.
