Home › Forums › General Discussion & Questions › General Discussion & Questions › B&O Core crashes
- This topic has 16 replies, 4 voices, and was last updated 12 hours, 38 minutes ago by
Stephen.
30 May 2025 at 17:06 #65932
Stephen
BRONZE MemberHi,
Does anyone else have a problem with their Core crashing for no apparent reason? Mine crashes on a regular basis, on average every two weeks but sometime twice or thrice in one week. I reported this to my local B&O dealer a couple of months ago and they gave me a replacement. However, this one crashes regularly too. When it happens, I unplug the device and reconnect it a few seconds later. After a minute or so, it is back to normal. It’s an irritating problem and I’m interested if it affects anyone else.
Thanks.
Stephen
Location: Switzerland30 May 2025 at 17:56 #65934BRONZE MemberAre you on ethernet or Wifi? What is it doing when it crashes?
Location: Toronto, Canada30 May 2025 at 18:00 #65935Stephen
Whether I’m on wifi or ethernet makes no difference.
Location: Switzerland30 May 2025 at 18:07 #65936BRONZE MemberSo you tested both? Whats it doing when it crashes?
Location: Toronto, Canada30 May 2025 at 18:11 #65937Stephen
BRONZE MemberYes, tested it both with wifi and ethernet. When it crashes, the music just stops. The Halo can no longer find it; says it’s offline. The only solution seems to be to reboot the Core.
Location: Switzerland30 May 2025 at 18:27 #65939BRONZE MemberWhats the music source? basically what I am trying to figure out is that if the core is streaming music from online and there is some internet drop out or issue the core could get confused and crash.
Location: Toronto, Canada30 May 2025 at 18:32 #65940Stephen
BRONZE MemberI stream only with Deezer or with my personal DLNA library. I don‘t use other streaming services and I never listen to radio.
Location: Switzerland30 May 2025 at 18:37 #65941Stephen
BRONZE MemberI should add that I often listen to music from Deezer or Bandcamp or Apple Music by airdrop, as opposed to using the B&O app, through the Core. Makes no difference; it crashes regardless of source
Location: Switzerland30 May 2025 at 18:51 #65942BRONZE MemberGreat. but all of it is dependent on your router/hub/network if its deezer or airplay. Maybe attach something to the line in of the core that doesn’t use network at all and see what happens.
Normally I would say something is defective but if you got a replacement and there is no reported problems of this happening it could be caused by something on your end.Location: Toronto, Canada30 May 2025 at 19:29 #65943Stephen
BRONZE MemberThanks for your suggestions. I do appreciate your time and input.
My audio setup is very simple and I haven’t owned a TV for >20 years. I have the Core, Halo, MacBook and iPhone as my music system, sourcing Deezer, DLNA, Bandcamp or Apple Music. Apart from an old 9000 multi-CD player that is independent of the ether, that’s it! I don’t know what else I could connect to the ethernet cable.
My suspicion is that the Core might be susceptible to small power surges in the domestic electrical circuit. Nothing else connected to my router or wifi has a single problem. In fact, the only problems I ever have are with B&O devices… or their inconsistent, often crappy app!
Location: Switzerland30 May 2025 at 22:10 #65946GOLD MemberYou could try to connect a streaming source e.g. the Macbook (with a physical connection/a cable) to the aux input of the Core…
…in order to see, if the Core still drops out, when it does not depend on your wifi or ethernet connection.
Location: Flensborg————Danmark31 May 2025 at 07:13 #65949Stephen
BRONZE MemberYou could try to connect a streaming source e.g. the Macbook (with a physical connection/a cable) to the aux input of the Core…
Thanks for the suggestion, however, the core crashes are sporadic and unpredictable, usually a week or two apart; it would be totally impractical as my Mac gets moved around a lot.
Location: Switzerland31 May 2025 at 12:09 #65970NQVHNWI
FOUNDER MemberIm going to assume this is a BeoConnect Core (Mozart) and not a Beosound Core ( ASE) your talking about?
Additionally, what is the Core connected to? Sources/equipment/Loudspeakers etc?
This reply was modified 1 month, 4 weeks ago by
NQVHNWI.
31 May 2025 at 12:42 #65973Stephen
BRONZE MemberIt’s a Beosound Core wire-connected to a pair of Beolab 1 loudspeakers that have worked flawlessly for 20 years.
Location: Switzerland31 May 2025 at 13:44 #65992NQVHNWI
FOUNDER MemberOk, thanks.
i cant unfortunately help you with that. I am aware of sometimes the BC core fails to trigger the Shape (on but mute) from time to time and is cured be hard reboot of both (Shape first).
31 May 2025 at 14:04 #66008Stephen
BRONZE MemberStill, I appreciate the efforts. Thanks all.
It’s annoying but, if I disconnect then reconnect the Core, it works fine… Until the next time it crashes in a week or two… 😀
Location: Switzerland28 July 2025 at 09:26 #67953Stephen
BRONZE MemberUpdate on the mysterious BeoSound Core behaviour. It continues to crash at least weekly but seemingly at random times. I was pretty sure that this is nothing to do with WLAN, router or music source.
As mentioned before, I had wondered if something in the house is interfering with the Core. I noticed a few weeks ago that, if I opened or closed my electronically controlled window blinds. the Core, often but not always, seemed to just stop playing. This also happened once when the doorbell rang. I had put this down to coincidence previously but now I’m sure that, when opening or closing the blinds, the Core crashes.
My local B&O dealer discussed the problem with B&O and they suggested wrapping the Core in aluminium foil, as the dysfunction may be related to interference from various frequencies, such as those emitted by motorized blinds or similar devices. So, my Beosound Core is now shiny silver. Let’s see…
