Home › Forums › Product Discussion & Questions › BeoMaster › B&O 6500 damaged
- This topic has 2 replies, 3 voices, and was last updated 2 years, 1 month ago by
Dillen.
28 January 2024 at 02:19 #52458
Johannes
BRONZE MemberHi,
my beomaster 6500 had some heat problems and now there is some damage at the circuit board. I‘ll attach some pictures. Display is working normal but there is no Sound Output. Do you think it’s possible to repair this?
thx!
28 January 2024 at 22:25 #52459 filip_kbhBRONZE MemberShould be fixable. But why was it overheating in the first place? Idle current may have been set too high due to corroded trimmers. But as there are parts that actually burned, I suspect a short-circuit may have happened. I am sure other experts here can tell you what happened.
Start with cleaning the board with a clean paint brush to get rid off all the dust.
The damage seems to be only in one area of the board. Find out what the shared denominator is for those four parts to burn up. Then order new replacements. When desoldering on this board, do not use too much heat as you will lift traces. Also – was the transparent plastic holder for the filter capacitors missing, or did you remove it to take the pictures?
29 January 2024 at 22:24 #52460Dillen
ModeratorBurned output stage.
Not a job for an untrained – with all due respect. Repairs like this can give even highly
skilled tech guys a good run for their money.Put short – replace everything from the differential amplifier outwards.
Then power up slowly using a variac while keeping an eye on the idle current and DC offset. Follow up with adjusting the idle.Martin
