Home › Forums › Product Discussion & Questions › BeoMaster › BM 6000 (Type 2252) – constant hiss on one channel
- This topic has 2 replies, 3 voices, and was last updated 3 years, 8 months ago by
hcraig244.
22 July 2022 at 01:10 #36272
Beopol
BRONZE MemberHi, I’m new here as I bought beautiful set of classic B&Os (BM 6000, BG 6006, BC 6000, BV S80) but there are some issues. There is a hiss on right channel. The hiss has the same volume (quiet but noticable “ssssssssss”) regardless of volume of the music. Did you come across this problem before on BM 6000 or other amps?
Regards,
Tad
22 July 2022 at 09:56 #36273Die_Bogener
BRONZE MemberYes, it could be a broken ground connector or track on a board, broken solders.
When all sources have this problem, it is inside the (pre)-amp.
If possible and if the preamp can be disconnected: apply a different source carefully to the amp. If gone, it’s the preamp. If not, the amp.
If it is more a 50Hz humming sound: defect power source, dead caps.
22 July 2022 at 11:35 #36274hcraig244
SILVER MemberThis could also be a noisy transistor……I have had this problem in the past.
