Home › Forums › General Discussion & Questions › General Discussion & Questions › BGAdaptor – Control a Data Link source with Connected Audio
- This topic has 1 reply, 2 voices, and was last updated 53 minutes ago by
Tignum.
20 August 2026 at 09:49 #125098
cklit
ModeratorHi all,
I have been tinkering with (and using) a project I call BGAdaptor for a while now, and thought it might be of interest in this forum.
The BGAdaptor contains a small ESP32 microcontroller and a few extra components, that is disguised as a slightly larger-than-normal 7-pin DIN to 3.5 mm jack adaptor.
It works with both Mozart and ASE-based products, and with Beogram turntables and CD players. Beocord tape decks are also supported (yeah, that was an after-thought, but I decided to keep using the BGAdaptor name ;)).
The Data link source plugs into the DIN end, the jack goes into Line-in on a network connected Bang & Olufsen speaker. Inside the box, the ESP32 is wired to the Datalink pins where it can send and receive data signals, and at the same time it listens to the event stream from the speaker over WiFi. This means that I have bidirectional control between the speaker and Data Link source; select Line-in and the Beogram starts playing. Switch source and it stops. Standby switches it off.
Setup and a control interface is available on a web page hosted by the adaptor itself, all local, no cloud. You can even hook it up to Home Assistant and expand functionality further 🙂
Here’s an older video of some of the things you can do (the web interface has changed A LOT since): https://youtu.be/YJ0Ucw3CIwc
Everything is open source and you can see more here: https://github.com/cklit/BGAdaptor
21 August 2026 at 15:14 #125137 Tignum
GOLD MemberHello cklit, wow supercool, and so small! Does it take power from the BeoGram?
This would also work with the Line-In of an M3 or M5?
Regards,
Johan
