Home › Forums › Product Discussion & Questions › BeoVox › Beovox RL140 scam – help needed
- This topic has 2 replies, 2 voices, and was last updated 3 months ago by
Tignum.
13 November 2025 at 17:26 #71148
Amine Houari
BRONZE MemberHello everyone,
I bought a few months ago a pair of RL140, and I had them stored for a while. Now that I have more time, I decided to redo the speaker cloth, so I opened both of them, and found a very very bad surprise inside: the woofers (2 in each speaker) have been replaced by cheap $15 generic 8 ohm speakers of the same size. The sound is horrible, and after digging a little bit, I also find out the the woofers, which are connected in parallel to the crossover, should be 16 ohms (as the entire speaker is 8 ohms).
I have been scammed and have no contact with the seller because it was a while ago (they may not even be aware of what was inside anyway). So I want to repair the RL140s, and I can’t find those parts, let alone finding 4 of them.
Can anyone point me to a good source for those ? Alernatively, I am willing to do a better-than-nothing approach, and replace them with “good enough” 16 ohms drivers if anyone can help me with guessing/estimating the correct specs: 16 ohms, probably around 40-50 watt, precision of 88-93 db, what else ?
Thanks everyone for any help you can provide.
Amine
Favourite Product: Beogram 4002
Signature: Beomaster 3300, beogram 3000, beocenter 9500, beogram 4002, beovox RL-60, Beovox RL-35, Beolab 6000
14 November 2025 at 21:40 #71175Amine Houari
BRONZE MemberOh I am pretty sure someone in here has an opinion or advice on this ? 😎
15 November 2025 at 09:34 #71183 TignumGOLD MemberHello Amine, nice speakers. And big!
Often drivers were made specifically for B&O speakers, so finding a substitute with the same characteristics will not be so easy. I reckon finding a donor set (with the aim of making one great set out of two bad ones) is your best bet. Foam & rubber surrounds can be obtained from https://www.repairyourspeakers.com/en/, capacitor kits from https://www.dksoundparts.com/product-category/beovox/beovox-redline-rl140/. Sometimes magnets should be reglued (there are threads in the forum). When becoming a silver or gold member you can get to the service manuals (perhaps the same drivers are used in other RL speakers too?)
Hope this helps (a bit).
Regards,
Johan
This reply was modified 3 months ago by
Tignum.
