Home › Forums › Product Discussion & Questions › BeoVox › Beovox 3702 Crossover Capacitor Values
- This topic has 2 replies, 3 voices, and was last updated 1 year, 4 months ago by
Stephen Lothridge.
15 April 2024 at 12:45 #54290
tinhat
BRONZE MemberHello. Hoping for some help with a pair of 3702s I’ve acquired. First job is replacing crossover caps and re-foaming the woofer – unfortunately the print on the woofer capacitor is not readable – does anyone have the values?
Many thanks.
15 April 2024 at 15:19 #54291Dillen
ModeratorDepends on the type of Beovox 3702.
Kits are readily available:
https://www.beoparts-shop.com/?s=3702&post_type=productMartin
17 October 2024 at 06:13 #60216Stephen Lothridge
BRONZE MemberRegardless whether you ended up buying the kit or not, I thought I’d post the values in my 3702 6244’s. I’m also replacing the caps in mine so I took pictures and recorded the values.
The values are 3.3uF, 8uF, 37uF, and 50uF; all 25V.
If anyone happens to know exactly which caps are in the kit, that would be great to know since the product page doesn’t say.
Steve
(I originally thought the 3.3uF was a 2.0uF, that’s why there’s a picture called 2.2uF Cap)
You must be logged in to view attached files. -
