Home › Forums › Product Discussion & Questions › BeoVision › Beovision7-40
- This topic has 2 replies, 2 voices, and was last updated 2 years, 6 months ago by
loureed5.
1 March 2024 at 09:37 #53167
loureed5
BRONZE MemberI have a Beovision 7-40 – Type Number : 9351 .
Can anyone tell me if this is a HD TV>?
Noel
2 March 2024 at 08:29 #53168 RavstedBRONZE MemberHi,
Depends how you define HD.
It has a 720p panel (HD) but not all of the type 9351 had HDCP. However, the lack of HDCP can be bypassed by adding a cheep HDMI splitter which are known to removing the copy protection.
So, you got HD resolution over the DVI input.
But you might not have HDCP compatibility which is required to make it so called ‘HD Ready’.
Edit: No HDMI by the way…
2 March 2024 at 09:06 #53169loureed5
BRONZE MemberThanks for the info Ravsted.
Much appreciated.
