Home › Forums › Product Discussion & Questions › BeoVision › BeoVision Eclipse Mk1 Screen Upgrade
- This topic has 4 replies, 3 voices, and was last updated 9 months ago by
Beoet.
22 May 2025 at 13:09 #65740
Beoet
BRONZE MemberHi, anyone consider upgrading their C7 OLED panel on the Mk1 Eclipse using the new adapter from STBbrackets?Our 2018 65″ Eclipse is suffering from burn-ins, and I consider ordering this adapter.22 May 2025 at 16:42 #65741 Severed_hand_of_skywalker
BRONZE MemberI haven’t used it but people seem to like STB brackets.I also can’t believe an OLED from 2018 already has problems. My Sony OLED from 2015 is still going strong. Did you have a lot of static images with logos on your screen a lot? Just curious.Location: Toronto, Canada
26 May 2025 at 07:39 #65820Beoet
BRONZE MemberSeveral burn-ins (e.g. from Youtube etc).The only downside with getting a new C4/C5 panel is that the new panels are significantly narrower than the original C7 panel (for the 65″ I think the new panels are 12.6 mm narrower than the original one). Meaning that the edges will not align with the lower glass panel…. The picture quality should be really bad to sacrifice esthetics (Eclipse is a successful and timeless design IMO)!If STBbrackets could have provided a 3 edges “click-on-frame” to fill in the 6.3mm width on each of the 3 sides for the new panel, I think upgrading would be a no-brainer!
26 May 2025 at 22:01 #65837Mbee
BRONZE MemberI thought I would see the difference in size between the TV and the lower glass panel, but in real life it’s not noticeable.3 July 2025 at 10:08 #66763Beoet
BRONZE MemberDoes that mean that you’ve installed the screen adapter, Mbee? 6.6 mm narrower on each side is a bit, and I thought it would be noticable?
