Home › Forums › Product Discussion & Questions › BeoVision › Beovision Avant 75 NG only Green dot light
- This topic has 7 replies, 5 voices, and was last updated 1 year, 6 months ago by
Gene Ku.
26 March 2024 at 10:38 #53832
danielrs
BRONZE MemberHello dear B&Oworld members.
I’ve one Avant 75″ NG, Type 8875, SN 27313906. The TV have 7 years and allways work without major problems.
Last week screen remains black and only have the top small light green.
I try the regular procedures, Power ON/FF cable, and allways same. Only have green light. Soundbar don’t go out, and not response to remote control.
Tv was disconnect several days from power cable just to check if something happend, but today i turn on cable and same situation.
I disconnect all cables, just plug power cable and same situation.
I’ve try search in this forum but didnt find anything.
Any one can help me? Can be firmware problem and i can reset from USB pen for exemple?
Thanks for all assistance.
Daniel RS1 August 2024 at 02:43 #57823Gene Ku
BRONZE MemberHi,
Did you ever get this fixed?
G
1 August 2024 at 11:57 #57858 multicareGOLD MemberThis sounds like a video engine issue.
It will need to be replaced.
2 August 2024 at 20:38 #57927Gene Ku
BRONZE MemberWhat if the red LED just blinks slowly?
1. Screen never turns on.
2. Speaker never descends.
3. Doesn’t connect to the B&O App nor the router.
4. No option to enter the PIN.
I have tried other IR remotes with no luck–no response. The BeoRemote One which was paired with the Avant NG seems to be working, but I can’t confirm, but no reaction to it.
Any ideas?
2 August 2024 at 23:12 #57928 multicareGOLD MemberWhat if the red LED just blinks slowly?
Generally this is in indication that the pin number needs to be entered, as you have no image on the screen obviously you are unable to enter the pin number.
I would suspect that the video engine is at fault.
6 August 2024 at 06:20 #58028beouser19
GOLD Memberif green light lit and tv not turn on, it can be videoengine fault or if lucky cable between VE and BT module
19 August 2024 at 15:09 #58458 beotexBRONZE MemberHave you tried connecting via the app? My Avant NG will sometimes “freeze” with the green light and do nothing. I go into the app and put everything into standby, and that usually triggers it to turn off, then it works ok. It’s not often, but the app seems to trigger a reset of the TV.
19 August 2024 at 17:55 #58463Gene Ku
BRONZE MemberThanks Beotex,
No, it doesn’t connect to the app nor the router (via ethernet).
I’ve tried something new: Changing the Video Option using IR, but no response.
Any other ideas?
