Home › Forums › Product Discussion & Questions › BeoVision › beovision avant 55 4K purple screen with lines
- This topic has 7 replies, 7 voices, and was last updated 1 year ago by
Sergi0.
17 May 2023 at 03:31 #46684
nitro2
BRONZE MemberCan some member give repair info on this quite recent unit ?
service manual ?
partnumber of the video engine board ?
17 May 2023 at 21:42 #46685 MillemisBRONZE MemberCommon desaster with the Avant 1st gen.
You will have to let a certified B&O technician do this job – the new DVE has to be programmed for the tv in case.
I have never heard of anyone doing this on his own.MM
18 May 2023 at 13:09 #46686 DanielBRONZE MemberHappened twice on my Avant, and I guess it will happen again. I believe the design is too thin and heat slowly kills the DVE. If the set will be on for a long session, remove the back plates.
There is no chance to replace the DVE on your own. It takes several hours for a skilled B&O technician to replace the DVE including reprogramming the set using a computer connected to B&O.
18 May 2023 at 21:13 #46687 trackbeoBRONZE MemberAfter it is repaired, @beowillie suggested using the pins on the USB connector to drive a tiny heat sink fan internally — at half-voltage so it doesn’t make noise — and “strategically placing” it inside the case. He rather hand-waved verbally on the BeoTalk podcast as to where he shoved it, but apparently with the case open this was obvious?
3 August 2024 at 23:31 #57976Sergi0
MemberI did change the video engine myself after the reference for the faulty one were provided. I get a new board (might be a refactored one) and it took me around 30mn to install the bew board in the TV. It is not a complicated operation to do, as long as you have the service manual and the right screwdriver 🙂
S.
6 August 2024 at 06:16 #58027beouser19
MemberHi,
from ebay? If you get a used dve you can change it by your self, but it have a different serialnumber then, thats doesnt matter if pincode is known or disabled
19 January 2025 at 20:46 #62904Christian Bavnhøj
BRONZE MemberHello @Sergi0! Where did you find the board? Would there be any chance that you could provide a more detailed description of the process?
16 March 2025 at 18:20 #64525Sergi0
MemberHi,
I get the board from SkynexAV. I had to provide my Avant serial number for the new board to be compatible, but once I received it, I was able to remove the backplate of the TV and change the board.
It is a couple of screws and connector to remove and replace. Being patient and taking pictures may help. Once it was installed, I don’t remember if I had to enter a new PIN code, but as the TV is still working, I might have done it.
Cheers,
Sergio
