Home › Forums › Product Discussion & Questions › BeoVision › Beovision 7 – contacting STB and Firestick
- This topic has 2 replies, 2 voices, and was last updated 2 years, 9 months ago by
julesWales.
25 June 2023 at 04:10 #47375
julesWales
BRONZE MemberHi, we’ve recently picked up a second hand Beovision 7 Mk4.
I’ve managed to connect a firestick to HDMI A and can pick it up using the VMem on the remote control.
I can’t for the life of me work out how to also connect a BT You view box too. It is in HDMI C on AV2 but I can’t select it on the remote control and there doesn’t seem to be an obvious way to do it. It’s currently a V Aux selection on connections.
I’ve gone through the instructions to register the device (unknown STB) but then how do I actually connect to watch? Many thanks25 June 2023 at 16:22 #47376 MillemisBRONZE MemberIf your problem is, that you can not find a button on the remote to do this (V-AUX), you can find this button by adding it to the List.
This way you just push List multiple times – or just one, if it can be moved to the first place there.Here is how to add items to the List on the Beo4:
25 June 2023 at 16:45 #47377julesWales
BRONZE MemberThank you so much – that has cracked it!
