Home › Forums › Product Discussion & Questions › BeoVision › Beovision 7-32 with Beosystem 3
- This topic has 22 replies, 2 voices, and was last updated 1 year, 9 months ago by
CharlieWednesday.
28 October 2024 at 17:29 #60514
CharlieWednesday
GOLD MemberThanks. Yes that setup does work if I use the BV7 instead of the BS3. I’ve already ordered the cable, I’m pretty convinced now that this is what I need – I don’t think the BS3 option setting is working without using it’s own IR eye, as you suggest.
I’ll let you know if it works once the cable arrived.
29 October 2024 at 10:12 #60555 CharlieWednesday
GOLD MemberBy the way, does anyone know how you can get the software updated on a Beosystem 3 Mk2? It doesn’t have the USB socket like the Mk2 has. I assume this was something a B&O shop would do, but I don’t know if today’s shops would even recognise it!
29 October 2024 at 19:39 #60572 CharlieWednesday
GOLD MemberMy attempts to set up a B&O home cinema seems to be more complex than I thought! I encountered a whole new unexpected issue today.
I am not yet using the Beosystem 3 for the reasons given earlier in this thread (and may never use it, if it turns out to be no use to me), but I thought I would set everything up just using the Beovision 7’s VGA Cinema output, connected to my projector, which has a VGA input.
Because my Beovision 7 (Mk3) does not have HDMI inputs I have a 3 way HDMI switch box and audio splitter, which in turn is connected to the DVI input and RCA audio inputs of my Beovision 7. Thet HDMI switch box has a Nintendo Switch, and Nintendo Wii U, and a Google TV connected to it. They all work fine when watching on the BV7 itself.
So, I switch to the projector screen using Format 0 on the Beo4, and everything works fine except the Google TV. DTV and DVD from the TV are both fine, both Nintendo consoles are fine, but when I try to switch to Google TV, I get a message only if using the projector – the message ‘Content is protected – select another source’ is displayed. I am not sure if it is the TV or the projector which is generating that message, but I think it’s the projector.
I found this post on the old forum from someone who had a similar issue but with a Beosystem 3. It seems that their screen was not HDCP compliant, but I have checked the manual for my projector, and that is HDCP compliant. I don’t know anything about HDCP and had never heard of it until today, but I assume the BV7 must be HDCP compliant as the Google TV works fine when not in cinema mode.
So, I’m left wondering, is it because I am using a VGA-to-VGA cable to connect the TV to the projector? If I get a VGA to HDMI converter and connect that to one of the projector’s HDMI inputs instead, is it likely that will work?
