Home › Forums › General Discussion & Questions › General Discussion & Questions › Beovision 11-46 wall mounting
- This topic has 12 replies, 3 voices, and was last updated 1 day, 9 hours ago by
21 January 2025 at 22:53 #62980
Paul9367
BRONZE MemberHi
i was luck enough to be given an 11-46 with the hinged wall mount. ย Are there any instructions on how this is mounted. I canโt see anything online. I can see the plate attaches to the wall but not to sure how to attach the tv. ย On the right hand side of the beovision, I can see the parts that swivel, do these locate onto the plate on the wall and screw in?
21 January 2025 at 23:09 #62981GOLD Member21 January 2025 at 23:22 #62982Paul9367
BRONZE MemberHi Mm
That is really appreciated. It does not look easy but I will have a look tomorrow and see if figure this out
Tusand tak
25 January 2025 at 22:19 #63083Paul9367
BRONZE MemberHi Millemissen
i have looked at the bracket, it looks like Iโm missing the screws for the the bracket that attaches ย to the tv, there are 7 small countersink screws ย that attach to this the hinges. I have attached a picture just not sure what the size is ?
You must be logged in to view attached files.25 January 2025 at 22:28 #63086GOLD MemberCould you maybe describe what you actually have!
Maybe someone else can chime in ?
It is a long time since I dealt with that – do not remember exactly.
Iโd have to stand in front of one to recall it.However this is what it looks like, when installed:
MMLocation: FlensborgโโโโDanmark25 January 2025 at 22:36 #63087Paul9367
BRONZE MemberHi
i have the two parts of the bracket A and B and I also have the countersink screws for all hinges that allow the bracket to mounted to the tv as well as the wall bracket the only parts I appear to be missing are the small countersink screws they are ย called 7 X DB othe only one Iโm missing is 1 x DA according to the manual you kindly linked to
25 January 2025 at 23:07 #63088GOLD MemberLocation: FlensborgโโโโDanmark25 January 2025 at 23:09 #63089GOLD MemberBest consult an installer.
They might have installed one of these recently – maybe they have the spare parts.Location: FlensborgโโโโDanmark25 January 2025 at 23:12 #63090Paul9367
I will ask them and see if they can advice will post back and let you know thanks for all your help
1 February 2025 at 14:19 #63291BRONZE Member1 February 2025 at 15:31 #63293Paul9367
BRONZE MemberHi Graham
Thanks for info, unfortunately I have a plasterboard wall, on outside of the bracket I can luck I can hit the studs they seem to fit the bracket perfectly they are Cutter Pozi Screw 6.0 x 70mm. Once ย I have installed the BVIS
9 March 2025 at 22:05 #64409Paul9367
BRONZE MemberI have now managed to mount the bv11-46 on the wall bracket. I have two questions is it easy enough recover the fret on the speaker? The other question is the bracket. I can move the wall bracket to different positions manually but I donโt see any lead to plug it into the socket marked stand on the tv?
11 May 2025 at 15:20 #65530BRONZE MemberDid you resolve this? You need the separate hinge motor that plugs direct to the TV after locating it in position.
As far as the fret cover is concerned I would remove the fret from the TV and then paint it with fabric dye. You will never get a good fit by applying new fabric in my opinion.
Graham
