Home › Forums › General Discussion & Questions › General Discussion & Questions › BeoVision 11-46 burned component.
- This topic has 3 replies, 3 voices, and was last updated 2 years, 3 months ago by
Gene Ku.
3 July 2024 at 01:12 #57156
Gene Ku
BRONZE MemberGreetings!
My BV11-46 started crackling and smoking and when I opened it up, this is what I found (one or both capacitors probably went bad). Is it better to repair these (and potentially other components) or replace the whole board? What are options (US or Europe/Poland preferrably)? Expected costs? If these went bad, anything else that should be replaced?
Also need a replacement glass…any suggestions?
Thanks!
Gene
You must be logged in to view attached files.4 July 2024 at 13:04 #57182 AdamSBRONZE MemberThose are the standard mains suppression capacitors that have been fitted to most electronics since the 1970s. They can fail and, when they do there’s usually a bang and some smoke, but I would have though this TV was far too young for that.
I wonder if this is tied in with a visit we had a year or two back to change out a board on our Beovision Eclipse TV as a “preventative maintenance precaution” due to a potential failure issue that had been identified? As I’m in the UK, our lovely new forum owners, Multicare, contacted us directly and came and did the job for free, but I wasn’t home that day so didn’t find out exactly what it was they changed.
As the TV is fairly recent, I would say that your best port of call initially would be a B&O dealer if you have one nearby.
5 July 2024 at 19:24 #57232 BeobuddyBRONZE MemberJust replace those two paper foil capacitors. As said, it a common thing.
I’ve already done some, these were also boards from BV11’s. But also some psu’s from Essence mk2’s and ML/NL converters.
After replacement the powersupplie will work again.Location: Utrecht
6 July 2024 at 04:45 #57236Gene Ku
BRONZE MemberThank you AdamS and Beobuddy!
