  • #64588
    Paul9367
    Finally have my Beovision wall mounted, the two problems I have there appears to be no std by indicator even when on I believe it should be green? The other issue is visual my wife does not like the red cover she would prefer white or black is it possible to do this with some speaker fabric? This is the magnetic speaker cover
    #64597
    Millemis
    GOLD Member
    I recommend reading the User Guide
    IMG_1132
    Depending on where you are located, it should not be that hard to find and buy a different frontcover (even wooden ones are available)….…….unless you really want to DIY 😉
    #64599
    Paul9367
    Hi Mm
    i did read the manual, there is no light on the prism display, but the tv is switching on. The speaker cover I have had a look and I can’t see anything in Scotland, used to be a company down south that used to do that
    #64656
    Hiort
    Just to be clear: The green light is there only during startup, when no picture is present. The green light is there when you e.g play music to the BV11, not using the screen.
    #64702
    Paul9367
    Hi Hiort
    Thamks for the info, I was not aware of that, it looks like there is no traditional std by like the BVIs 7’s of old. That was my last tv until now 🙂
