Home › Forums › BeoWorld around the world! › Dutch › beosystem3 linked with beosound 9000 gives surround,no stereo
- This topic has 7 replies, 4 voices, and was last updated 2 years, 4 months ago by
kriskarmann.
29 October 2023 at 05:23 #49924
kriskarmann
BRONZE MemberHey B&O friends ,I have a beosystem 3 all set with 4 Beolab 1 speakers and a Beolab 2 subwoofer and a beolab 7.6 center speaker . Also I have my beosound 9000 (MK3) connected with a masterlink cable to the beosystem 3.
Now , the sound is perfect for movies with all speakers working correct for surround but when I put on my beosound 9000 and play a CD (for example) it plays surround sound . only vocals to the center and front speakers and not to the rear ones.
Sound rather strange …as I expected to have stereo sound for my music and surround for movies.
anyone know what to do to get it right?
thanks
29 October 2023 at 19:37 #49925 TignumGOLD MemberHello kriskarman,
In the ‘sound adjustment’ menu there is the option to choose defaults for audio and video. For ‘DEFAULT AUDIO’ it should then state ‘SPEAKER2’ for stereo + sub. Maybe have a look there first? Don’t forget to ‘STORE’ the setting.
Let us know what you find,
Regards, Johan
30 October 2023 at 15:35 #49926kriskarmann
BRONZE MemberThanks Johan , just changed it to setting 2 for AUDIO as you told me , but still the center speaker is working also , strange
regards,
Kris
30 October 2023 at 19:29 #49927 BeobuddyGOLD MemberYou might use “Speaker 2” instruction on your Beo4. List until “speaker” appears, then press 2.
30 October 2023 at 22:38 #49928 MillemisBRONZE MemberAre you sure, that the 7.6 is connected to it’s own powerlink socket called Centre 1.
31 October 2023 at 13:00 #49929kriskarmann
BRONZE MemberWell , I did manage to get it right this time , amazingly helpfull you all , thanks
now I can enjoy those beolab 1’s to the max ,
cheers,
Kris
31 October 2023 at 17:20 #49930 TignumGOLD MemberCool! Impressive set :-).
What was the issue in the end you think?
Regards, Johan
1 November 2023 at 16:03 #49931kriskarmann
BRONZE Memberwell I tried to put it on “speaker 2” but that only put power to the 2 front speakers.
then I put it on “speaker 4” and than the fronts and back speakers worked with the subwoofer. All fine now ,
Thanks,
Kris
