Home › Forums › Product Discussion & Questions › BeoSystem › Beosystem 3 with LG Projector – blinking image on HDMI
- This topic has 3 replies, 2 voices, and was last updated 9 months, 2 weeks ago by
Tignum.
26 April 2025 at 16:04 #65327
CharlieWednesdayGOLD MemberI’m having an odd problem with my Beosystem 3, and I just cannot figure it out, so it’s back to the Beoworld Forum again!
I have a Beosystem 3 Mk2, connected to an LG HD short-throw projector (Cinebeam HF65L), using a DVI to HDMI cable. It’s working fine when I view the menu system or when I watch digital terrestrial TV via the built in DVB tuner. I am however having a problem when I try to watch connected HDMI.
I have connected a couple of HDMI devices to the BS3 and set them up in the connections menu as ‘Other’ devices. They are a Google TV streamer, and a Nintendo Switch console.
If I try to view either of those HDMI sources, the screen blinks on and off, the image is only seen for a fraction of a second, then it just keeps blinking on and off.
I don’t think the BS3 is faulty though. I tested it by connecting the BS3 to an HD monitor, and it worked fine connected to that – no blinking.
I know that my projector works as it works fine when HDMI devices are connected to it directly, but for some reason, the HDMI source going through the BS3 then to the projector is not working, and I only get a blinking image.
I have two DVI to HDMI cables and I’ve tried both, with the same issue.
I used to have a BS3 connected to an older projector (that was 720p rather than full HD but still connected via HDMI), and I never had the problem with that older projector.
27 April 2025 at 08:13 #65335 CharlieWednesdayGOLD MemberFigured this out – or at least partly. For some reason, if I connect my projector to the DVI2 output instead of DVI 1, the blinking does not occur.
That’s a bit inconvenient as I have no intention of connecting a normal TV screen to DVI1 – my Beosystem 3 is intended solely for use with a projector, but at least it works.
I’m assuming the DVI1 and DVI2 outputs on the BS3 must be configured differently in some way. The manual does say that the projector should be connected to DVI1 if you’re only using a projector, but that doesn’t work for me (not with this newer projector, anyway).
5 May 2025 at 15:09 #65437 CharlieWednesdayGOLD MemberI figured this out by the way, and I now have the projector working fine connected to DVI1.
The BS3 in question used to be used with a BV4, and as a result the Display 1 setting had been set for that. When I went into the Customer Service menu (Menu, move over Options, Red, Go), then went into the Picture Adjustments menu, I found that the Framelock setting for Display 1 was set to ‘Nearest Line’ whereas the same setting for Display 2 was set top ‘Double Buffer’. I changed the Display 1 setting to ‘Double Buffer’, and that solved the problem – no more blinking!
6 May 2025 at 19:19 #65464 TignumGOLD MemberThanks for sharing the fix! I am sure someone someday will google this and benefit.
And enjoy watching :-). Regards, Johan
