Home › Forums › Product Discussion & Questions › BeoSound › Beosound stage in combination with Beosound 1
- This topic has 2 replies, 2 voices, and was last updated 2 years, 2 months ago by
Hiort.
12 January 2024 at 09:03 #52106
Alenn
BRONZE MemberHi everyone,
I currently have Beosound 1 as main speaker for listening to music and I am wondering to add Beosound Stage in the same room for better music experience. Does anybody know if I can combine Beosound 1 and Beosound Stage in the same room as connected speakers? I have some concerns about the sync between both speakers and possible delay/lag between them.
Thanks a lot!
13 January 2024 at 10:01 #52107 HiortGOLD MemberYou are able to use them simultaneous, using Beolink. Meaning you start the source on e,g Beosound 1 and then add Stage to that play (ideally using the B&O app). They will play in sync.
Both need to be on the same network.
(I assume your Beosound 1 is the conic aluminium speaker 🙂
13 January 2024 at 10:03 #52108 HiortGOLD MemberNoticed just now that you wrote “connected”. Its not possible with physical connection. BS1 has no Line in / Out.
