Home › Forums › Product Discussion & Questions › BeoSound › Beosound Stage as center speaker in a 5.1 Setup
- This topic has 6 replies, 5 voices, and was last updated 11 months ago by
barchy.
24 November 2023 at 11:23 #50703
Gman
BRONZE MemberHi
I know that it’s not possible to have the Stage Soundbar as Center speaker in a normal 5.1 setup.
But do somebody know ifs possible with using the Almando surround Decoder in a LG C3 5.1 setup?
thanks
25 November 2023 at 12:07 #50704 MillemisBRONZE MemberThat is not possible – unless you’d use the line-in connection of the Stage.
But it would make no sense – too fiddly and totally run contrary to the purpose of the Stage.
Why not just choose a Beolab center speaker such as the 7-4 or one of the 7-x line?
That would give you a powerfull center speaker with the Almando.If you are after the smart audio functions of the Stage, connecting a Core to the Almando would be the better choice.
25 November 2023 at 13:59 #50705 Steve at Sounds HeavenlyGOLD MemberHi,
I am sorry but the Stage cannot be used with any other speakers, this is due to a sound delay in the Stage that cannot be removed. This would cause the Stage to echo after the other speakers have sounded.
Stage is a stand alone speaker only, there is no option to use it with any other speakers.
Kind regards Steve.
26 November 2023 at 15:50 #50706Gman
BRONZE MemberOk. Will it then be possible to connect an soundbar of another brand (LG?) to a Almando decoder. I find the Beolab 7 very big? I’m not sure because the Almando har RJ45 sound output and the most non B&O has not that possibility ?
26 November 2023 at 16:24 #50707 MillemisBRONZE MemberRJ45 is just a connector type – important is that it is a PowerLink connection.
There are lots of adapters/cables for RJ45 <-> DIN.
So that should not be a problem.You can also use a single Beolab speaker – for example a BL4000.
11 February 2025 at 13:28 #63690Beo_Andy_2022
BRONZE MemberThe new Almando can use the Stage as Center speaker. Anybody has experience with this New Receiver?
10 May 2025 at 18:50 #65521barchy
BRONZE MemberAs i see Almando says that it is possible to connect stage as center speaker, has anybody tested this option? maybe it is a good option with beolabs 8000 to make a 5.1 system, please tell us reports, thanks
