Home › Forums › Product Discussion & Questions › BeoSound › Beosound Ouverture no power and dead.
- This topic has 4 replies, 3 voices, and was last updated 1 year ago by
soloAudio.
28 February 2025 at 16:12 #64210
Jan
BRONZE MemberHello,
I have several Beosound Ouvertures to fix and one of them doesn’t power up. I suspect that a fuse is blown up but I can’t find it on the transformer-PCB 15. When putting the power on I hear a little hum, barely audible. I have looked at the service manual, but I can’t find any fuse.
Any suggestions how to find the fuses or where to look?
Jan.1 March 2025 at 03:36 #64228 Capt’nGerard, formerly known as Gaea
GOLD MemberThere are I believe 3 fuses, but they don’t look like fuses.
more like capacitors, they are soldered on.
Maybe check out a service manual or check the printed text on the pcb’s
1 March 2025 at 17:14 #64244 Jan
BRONZE MemberThank you,
Then I have to dig in further and measure if one of them is broken.
1 March 2025 at 22:09 #64254 Capt’nGerard, formerly known as Gaea
GOLD MemberWhen you look on dk-soundparts.com and look for ‘fuse’ you will see how they look like.
21 March 2025 at 22:59 #64608soloAudio
BRONZE MemberHi! I recently took mine apart (similar problem). When you remove the plastic back, on the left you will see the soldered side of the fuses. Mine had five of them. The PCB is silkscreened F1 through F5. When you look from the side, you can see they look more like cans, as previously mentioned. Mine were brown, about a 1/4″ high (~6.35 mm). It was easy to test them from the back. Hope this helps.
