Home › Forums › Product Discussion & Questions › BeoSound › Beosound Ouverture / 4000 CD Repair?
- This topic has 1 reply, 2 voices, and was last updated 1 year, 3 months ago by
Madskp.
19 December 2024 at 04:50 #61730
auric
BRONZE MemberHi:
I have beosound Ouverture / 4000 system. The CD has stopped working. The unit uses a CDM 12 laser mechanism (Linear pickup).
When I load a CD into the mechanism and hit “CD” the unit will not respond. The disc spindle motor does not spin. With the CD removed I can see that the laser lens is moving to focus. I can also see the red light of the laser on my phone camera.
In Test Mode, the laser turns on, and moves correctly.
I can also turn on the spindle motor (it spins anti-clockwise per service manual). I am unable to get it to play a CD in test mode. When select test mode 6, I get ERROR G. This error code is not described in the service manual. Any ideas
I’ve recapped the SERVO board on the back of the mechanism; no change. The CD laser was replaced several years ago and has seen very little use since. The laser does come on. Last time the unit played a CD was about 4 years ago. No problems at the time.
The battery inside the CPU has been replaced. I didn’t see that any special programming instructions after battery change.
Any suggestions for things to try?
Thanks!
Derek
20 December 2024 at 14:37 #61801Madskp
GOLD MemberThis thread is regarding repair of Ouverture and BC2300 https://forum.beoworld.org/forums/topic/beosound-ouverture-cd-not-working/
Maybe there could be some pointers for your fault finding although I cannot point at anything specific
