Home Forums Product Discussion & Questions BeoSound Beosound Moment using speakers via BV10
  • This topic has 2 replies, 2 voices, and was last updated 3 years ago by Kim.
  • #44252
    Kim
    As part of my little BS6500 NL-ML project I had to do some cable management and of course after having set everything up again, adding additional BLC. Well, of course now I can’t get the Moment to use the speakers connected to the BV10. The Moment is well and alive have connectivity via ethernet and on same network including that it can reach the DLNA-server and so on. But, if I press N.MUSIC nothing and the Moment doesn’t turn on; so a bit stuck here. Maybe a conflict with the second BLC to be used with BS6500. But, would anyone be able to point to a good setup or help out with a few points what to check for the setup with BV10 that have wired PL speakers together with the Moment.
    #44253
    carolpa
    go back to your original settings, as discribed in the other post.
    then start from there
    #44254
    Kim
    Found the issue for the above and it was issue with ML cable in my LexCom panel and once isolated and found the issue the Moment is not once again available in the ML-network.
