Home › Forums › General Discussion & Questions › General Discussion & Questions › Beosound moment limitations
- This topic has 1 reply, 2 voices, and was last updated 1 year ago by
Hiort.
27 February 2025 at 09:21 #64139
20cen
BRONZE MemberHi all,
I would like to open this thread in order to list all the beosound moment limitations, due to software no more updated.
I heard that the radio does not work anymore (because of TuneIn which is no longer supported) and also maybe deezer which also does not work properly. Is there any workaround (like using B&O radio instead of TuneIn)? Is there any other limitations ?
thanks
28 February 2025 at 09:32 #64180 Hiort
GOLD MemberIm quite sure that artwork will not be updated for music files you have on e.g. a NAS, so artwork need to be added manually.
Used to be picked from Gracenote if I recall correctly.
