Home › Forums › Product Discussion & Questions › BeoSound › BeoSound Level Setup
- This topic has 3 replies, 3 voices, and was last updated 3 years, 2 months ago by
Stan.
18 January 2023 at 07:52 #43083
terenceheath
BRONZE MemberHi.
Is it possible to set up the Level so that it automatically switches to aux input/line in if it detects a source?
I have a 9000 connected to a pair of Levels, but can’t get them to switch to aux when I play the CDs in the 9000. Thanks!
18 January 2023 at 21:04 #43084Mbee
BRONZE MemberTry to change the line input sensitivity under the sound settings.
18 January 2023 at 21:10 #43085terenceheath
BRONZE MemberThanks Mbee. I’ve tried setting it to high but that didn’t resolve it.
19 January 2023 at 17:15 #43086Stan
BRONZE MemberHow are they connected? PL to Aux-in? If so, I’d turn up the volume on the BS9000.
I think it’s also possible to connect from the BS’s AUX port… you just need to make sure to find an RCA to DIN cable with 4 RCA leads (2 input/2 output). However, as others have mentioned, the BS9000 needs to think it has speakers connected to it.
The auto-sense line-in works fine on my Balance (another Mozart speaker) – I have a turn table connected to it.
