Home › Forums › Product Discussion & Questions › BeoSound › Beosound Emerge ideal settings?
- This topic has 0 replies, 1 voice, and was last updated 2 years, 9 months ago by
Steve at Sounds Heavenly.
9 May 2023 at 04:54 #46514
GOLD MemberHi Beoworlders,
Many of you will know that I’m a huge fan of the little Beosound Emerge, which (when set up correctly) can punch way above its weight and give amazing sound. I wanted to share my favourite EQ setting for the Emerge, which I feel gives a good “in room” match to the Harman curve that I use on my headphones (this is an idealized frequency response that headphones should have in order to give a tonally balanced sound). For this to sound at its best, I suggest running the room compensation and turning on the Loudness option in the B&O app. Bass and treble are set to zero. Please let me know what your preferred settings are for the Emerge?
Kind regards, Steve.
