Home › Forums › General Discussion & Questions › General Discussion & Questions › Beosound Core and Eversolo Play
- This topic has 3 replies, 2 voices, and was last updated 5 months, 3 weeks ago by
YannChris.
11 October 2025 at 07:55 #70304
boj
BRONZE MemberTop of the Morning lads.
I have newly bought an Eversolo Play streamer to integrate with my Beosound Core through a coaxial to toshlink converter. The converter should work up to 192 kHz. When playing hi-res 24-bit 192 kHz my speakers make a lot of noise. From my Beosound Core I use powerlink cables to my Beolab 9’s. I think I read somewhere that the Beosound Core was reduced to Play up to 96 kHz when output is optical, but I use powerlink as output. Does anybody know where the problem lies? Are my coaxial- or toshlink cable too cheap , is the converter faulty or are my powerlink cables too thin?
When playing e.g. 96 kHz there is no problem.
Hope someone has encountered something similar or has the Knowledge to solve this.
thanks in advance.
11 October 2025 at 09:52 #70306 YannChris
GOLD MemberHi,
I have a similar problem with my setup which includes Core and BL50s.
I suppose that you feed the Core through it’s optical input and assume that the Core’s toslink input has the same limitations.
Here is an explanation found in the Beolab 50 technical guide:
13.10 Optical input not working
The Optical input will not accept sampling rates above 96 kHz due to unreliability of an optical digital audio connection at higher sampling rates.
Regards,
Yann.
11 October 2025 at 14:51 #70310boj
BRONZE MemberThanks Yann. That maybe sums it up. Have You tried a powerlink cable to the BL50’s through the digital powerlink output. I read somewhere that it was made for e.g. the BL 50’s.
Bo
11 October 2025 at 16:03 #70312 YannChris
GOLD MemberHi Bo,
Since my 50s are connected to a Theatre through Powerlink, I prefer to avoid any potential conflict between PL and DPL.
And to be honest, I didn’t notice the DPL output on the Core.
That’s the consequence of the lack of documentation available on the B&O “help” part of their site.
I really miss the detailed and complete paper guides which were previously available.
Because the skeletal FAQs with 2 or 3 items offered now is of no help for complex questions.
Regards,
Yann.
