Home › Forums › Product Discussion & Questions › BeoSound › Beosound Century (2000) Deck problem. Pls Help!
- This topic has 2 replies, 2 voices, and was last updated 2 years, 3 months ago by
Anh Minh.
5 January 2024 at 05:40 #51898
Anh Minh
BRONZE MemberHi every profesional! I’m using Beosound Century (the deck is made by Philips WT01 RER 5. When i push PLAY button, the HEAD did not move up to touch the TAPE. I don’t know how to fix it? Would you please tell me what’s happended? and how to fix it? Thks!
(All gears are not broke)
5 January 2024 at 15:25 #51899Dillen
ModeratorA common problem is a bad belt.
Is the motor running?Martin
5 January 2024 at 17:30 #51900Anh Minh
BRONZE Member- Thanks for your support. I already changed the belt (other type not same original, i bought in market. The big motor was not spinned. The smaller spinned a little bit ( you saw in video). Would you suggest me how to check and fix it?
