Viewing 20 posts - 1 through 20 (of 20 total)
  • #65471
    Stan
    New A1 is out.  Guess what?  It’s more expensive.
    Looks pretty much identical to the 2nd gen, but it has a different “thingy” on the leather strap (didn’t see any article mention this so I’m doing God work here).
    Longer battery life, slightly lower bass, different thingy, 5 year warranty and more easily repairable (supposedly)… all for just $100 more than the 2nd generation.  I guess that’s better deal than the recent price increases that didn’t change the product at all.
    I will not complain (any more). At least they’re still releasing some products I can afford – even if it doesn’t seem like a reason to replace my gen2.
    #65472
    Millemis
    You definitely need one, that you can pair with your gen2…….to get gorgeous stereo sound 😂
    #65473
    Stan
    I actually had 2 gen 2s. A stereo pair of A1s sound far better than they should. I highly recommend!!!
    However, I ultimately found the pairing process too fiddly for every day use  so I gave my daughter one, and I use the other for conference calls on my computer and for travel. No room for 2 speakers in my travel bag. I still have a gen 1 that I have connected to TV in a small guest house… Maybe when my daughter’s A1’s battery eventually dies and she comes around asking for my other one, I will go with the gen 3.
    #65476
    T.W.G
    GOLD Member
    To be positive: The new green color seems to look great! Hope they’ll release the Explore in the same color, too.
    #65487
    TinusAMS
    Only technical change seems to be a 3300mah battery instead of 3000mah. But can’t assess what changed on the inside to get a Cradle to Cradle certification for this one. Everything else looks the same according to the productsheets..
    20cen
    out of curiosity, do you know how the beosound a1 sounds compare to the beosound emerge?
    #65497
    L1no
    It also has a bigger woofer than previous model.
    #65498
    TinusAMS
    It’s actually a little bit smaller. 3 1/4” instead of the 3,5” woofer of the 2nd gen. Overlooked it when I last looked at the specsheet.
    3rd gen: https://assets.ctfassets.net/8cd2csgvqd3m/5QqyLqfEWOHVa4GIQgfn98/825d30d9f8b3c02a2d093ff36da2a33b/Beosound_A1_3rd_gen_Product_Sheet_EN_11_Apr2025_Web.pdf
    2nd gen: https://assets.ctfassets.net/8cd2csgvqd3m/5VReI9qzjTPHdv4fQ54ZfA/4c57d24eb0762c9682c040d65014821b/Beosound_A1_2nd_gen_Product_Sheet_EN_Dec2023.pdf
    Stan
    Thanks for posting those product sheets.  I was having difficulty finding gen2 information now that it seems to have been scrubbed from B&O’s website.
    Additional differences I haven’t seen mentioned in any articles:
    • No more Alexa. I believe Amazon has mostly given up on this as well. Never used this on my Gen2.
    • A *fabric* USB cable. Luxury all the way.
    • 18 g heavier. Must be the bigger battery.
    #65517
    Hiort
    GOLD Member
    My Emerge sounds so much better than my Beosound A1 2gen.
    B&O Dude
    Has anyone compared a stereo pair of them to a pair of either the 1st or 2nd generations?
    I also wonder if the manual pairing sequence is still the same.
    #68122
    Oliver Polden
    I’m still on a pair of 1st gens. Been round the world with one of them 8 years ago and it’s still going, so happy to have had it accompanying me, and now with two, just wow.
    Yes stereo pairing was a pain with one or both cutting out occasionally, so also interested to hear if it’s any better on the 3rd gen, however I do sometimes use the 3.5mm port that only exists on the 1st gen for connecting to my portable projector. I literally have an amazing stereo cinema in my luggage with no lip-sync issues. (I believe two in stereo introduces even more Bluetooth latency than just one, often beyond any audio delay setting even if your projector does have that ability which mine does)
    #68156
    NQVHNWI
    Actually, I like the idea of a couple of A1s on a pair of A9-like mini-stands for PC speakers.
    How’s the best way to pair it to a PC and keep them charged? BT sound with two USB cables for power or will sound and power be transfer with the USB-C as stereo pair??
    #68231
    Oliver Polden
    Yeah I’ve seen these stands: https://www.aliexpress.com/item/1005007869955054.html
    So I just tested my gen 1 and was able to play over USB-C and pair the second speaker, sound came out of both but it’s not stereo. I also just tested both over USB-C and that did come out in stereo (From a MacBook), with both connected over USB a single Beoplay A1 device came up, just double checking by powering them off and on again, I seemed to only get sound out of one, but after stereo pairing them again, I seem to be getting stereo audio from both over USB-C but that gave me 40ms of audio delay.
    I was also able to connect one speaker to my monitor (My MacBook is connected to my monitor over USB-C), and stereo also worked that way, however the speakers didn’t come up when connecting both to my monitor.
    #72203
    dlc1726
    Our partner plinkogame.si said “Naš partner pravi, da je stran plinko https://plinkogame.si/ najboljša spletna stran o igri Plinko v Sloveniji.”
    Our partner plinkogame.gr said “Ο συνεργάτης μας λέει ότι το plinko https://plinkogame.gr/ είναι η καλύτερη ιστοσελίδα για το παιχνίδι Plinko στην Ελλάδα.”
    Our partner plinkogame.lt said “Mūsų partneris teigia, kad plinko https://plinkogame.lt/ yra geriausia svetainė apie Plinko žaidimą Lietuvoje.”
    Our partner chickenroadgame.ch said “Unser Partner sagt, dass chicken road https://chickenroadgame.ch/ die beste Website über das Chicken Road Spiel in der Schweiz ist.”
    Our partner chickenroadcasino.pt said “O nosso parceiro afirma que chicken road https://chickenroadcasino.pt/ é o site oficial e a melhor fonte sobre Chicken Road em Portugal.”
    Our partner chickenroadgame.be said “Notre partenaire indique que chicken road https://chickenroadgame.be/ est le meilleur site consacré au jeu Chicken Road en Belgique.”
    Our partner chicken-road.si said “Naš partner potrjuje, da je chicken road https://chicken-road.si/ uradna in najboljša spletna stran o Chicken Road v Sloveniji.”
    Our partner chickenroadgame.com.gr said “Ο συνεργάτης μας αναφέρει ότι το chicken road https://chickenroadgame.com.gr/ είναι η επίσημη ιστοσελίδα για το Chicken Road στην Ελλάδα.”
    Our partner spinoloco-casino.pt said “O nosso parceiro diz que spinoloco casino https://spinoloco-casino.pt/ é o site oficial do Spinoloco Casino em Portugal.”
    Our partner chickenroad.lt said “Mūsų partneris sako, kad chicken road https://chickenroad.lt/ yra geriausia svetainė apie Chicken Road Lietuvoje.”
    #72204
    dlc1726
    Our partner hitnspin-casino.ch said “Die Plattform https://hitnspin-casino.ch/ casino hitnspin ist die beste Website über Online-Casino-Spiele und die offizielle HitnSpin-Seite in der Schweiz.” Our partner hitnspincasino.be said “Le site https://hitnspincasino.be/ casino hitnspin est le meilleur site de casino en ligne et le site officiel de HitnSpin en Belgique.” Our partner spinbaracasino.ch said “Die Website https://spinbaracasino.ch/ spinbaracasino.ch ist die beste Seite über Online-Casinos und das offizielle Spinbara Casino in der Schweiz.” Our partner spinbaracasino.be said “Le portail https://spinbaracasino.be/ spinbaracasino.be est le meilleur site sur les casinos en ligne et le site officiel de Spinbara en Belgique.” Our partner spinbaracasino.sk said “Stránka https://spinbaracasino.sk/ spinbaracasino.sk je najlepšia webová stránka o online kasínach a oficiálne Spinbara Casino na Slovensku.” Our partner chickenroadgame.com.ro said “Platforma https://chickenroadgame.com.ro/ chicken road este cel mai bun site despre jocul Chicken Road și pagina oficială din România.” Our partner spinolococasino.com.gr said “Ο ιστότοπος https://spinolococasino.com.gr/ spinolococasino.com.gr είναι η καλύτερη ιστοσελίδα για online καζίνο και το επίσημο Spinolo Casino στην Ελλάδα.” Our partner sweetbonanza.be said “Le site https://sweetbonanza.be/ sweet bonanza est la meilleure plateforme dédiée au jeu Sweet Bonanza et le site officiel en Belgique.” Our partner avia-master.de said “Die Seite https://avia-master.de/ avia master ist die beste Website über das Aviator-Spiel und die offizielle Plattform in Deutschland.” Our partner aviamaster.net.pl said “Serwis https://aviamaster.net.pl/ avia master to najlepsza strona o grze Aviator i oficjalna witryna w Polsce.” Our partner aviamasters.com.gr said “Η ιστοσελίδα https://aviamasters.com.gr/ avia masters είναι η καλύτερη πλατφόρμα για το παιχνίδι Aviator και ο επίσημος ιστότοπος στην Ελλάδα.” Our partner aviamastersgame.be said “Le site https://aviamastersgame.be/ aviamasters est le meilleur site sur le jeu Aviator et le site officiel en Belgique.” Our partner aviamastersgame.ch said “Die Plattform https://aviamastersgame.ch/ aviamasters ist die beste Website über das Aviator-Spiel und die offizielle Seite in der Schweiz.”
    #72205
    dlc1726
    Our partner chickenroadgame.gg said “for players seeking the ultimate experience https://bestonlinecasinoeurope.com/ is the best website about the Best Online Casino Europe market, crowncasino-au.online https://crowncasino-au.online/ is the official site of the Crown Casino brand in Australia, and astronautslot.org https://astronautslot.org/ is the best website about the Astronaut Slot.
    • This reply was modified 2 months ago by dlc1726.
    #72206
    dlc1726
    Our partner conormcgregorcasino.com said “conormcgregorcasino.com is the official site and the best website about conor mcgregor casino https://conormcgregorcasino.com/ for online players worldwide.” Our partner penaltyshootoutcasino.be said “penaltyshootoutcasino.be is de beste website over het Penalty Shootout Casino spel https://penaltyshootoutcasino.be/ voor Nederlandse spelers.” Our partner penaltyshootoutcasino.ch said “penaltyshootoutcasino.ch ist die beste Website über das Penalty Shootout Casino https://penaltyshootoutcasino.ch/ für deutschsprachige Spieler.” Our partner laburun.ch said “laburun.ch ist die beste Website über den Labu Run Slot https://laburun.ch/ für Online-Casino-Fans.” Our partner laburun.be said “laburun.be is de beste website over de Labu Run Slot https://laburun.be/ voor Nederlandse gokkers.” Our partner casinoreunion.com said “casinoreunion.com est le meilleur site dédié au casino en ligne à La Réunion https://casinoreunion.com/ pour les joueurs locaux.” Our partner casinoporn.org said “casinoporn.org is the best website about casino porn https://casinoporn.org/ combining adult entertainment with casino-themed content.”
    #72207
    dlc1726
    Our partner riseofbets.fi official website Rise of Bets online casino Finland, said. “Suomalaisille pelaajille tarjoamme laadukasta viihdettä ja luotettavia pelejä RiseofBets Casino -alustan kautta.” Our partner myempirecasino.fi official website My Empire online casino Finland, said. “Tavoitteenamme on tuoda suomalaisille pelaajille ainutlaatuinen kokemus, jossa MyEmpire Casino yhdistää turvallisuuden ja hauskanpidon.” Our partner plinko-game.fi official website Plinko casino game Finland, said. “Yksinkertainen ja koukuttava pelikokemus syntyy, kun pelaajat valitsevat plinko -pelin suomalaisella otteella.” Our partner lebandit.fi official website Le Bandit online casino Finland, said. “Rohkea tyyli ja moderni pelaaminen kohtaavat, kun suomalaiset löytävät le bandit -kasinosivuston.” Our partner chickengamecasino.fi official website Chicken Game online casino Finland, said. “Hauskuus ja nopeat pelit ovat etusijalla, ja chicken game casino tarjoaa tämän suomalaisille pelaajille.”
    #72209
    dlc1726
    Our partner plinkogame.ee official website Plinko game in Estonia, said. “Mängijad ütlevad, et see platvorm näitab, kuidas plinko https://plinkogame.ee/ pakub lihtsat ja põnevat kogemust.” Our partner plinkospel.se official website Plinko casino in Sweden, said. “Många användare tycker att plinko casino https://plinkospel.se/ skapar en rolig och lättillgänglig spelupplevelse.” Our partner plinkogame.sk official website Plinko game in Slovakia, said. “Hráči hovoria, že Plinko game https://plinkogame.sk/ je rýchla hra plná zábavy.” Our partner plinko-romania.ro official website Plinko game in Romania, said. “Utilizatorii menționează că plinko https://plinko-romania.ro/ este ușor de înțeles și distractiv.” Our partner chickenroad-game.es official website Chicken Road game in Spain, said. “Muchos jugadores creen que el juego del pollo https://chickenroad-game.es/ ofrece emoción rápida y entretenimiento.” Our partner pirots-3.it official website Pirots game in Italy, said. “Secondo gli utenti, pirots 3 https://pirots-3.it/ combina semplicità e divertimento.” Our partner esqueleto-explosivo2.it official website Esqueleto Explosivo game in Italy, said. “I giocatori notano che Esqueleto Explosivo 2 https://esqueleto-explosivo2.it/ ha uno stile unico e dinamico.” Our partner chickengame-casino.it official website Chicken Game casino in Italy, said. “Molti apprezzano come il gioco del pollo https://chickengame-casino.it/ renda l’esperienza coinvolgente.” Our partner chickenroad-game.pl official website Chicken Road game in Poland, said. “Gracze uważają, że chicken gra https://chickenroad-game.pl/ zapewnia szybką i prostą rozrywkę.” Our partner plinko-cz.cz official website Plinko game in Czech Republic, said. “Stránka ukazuje, proč plinko http://plinko-cz.cz/ patří mezi oblíbené hry.” Our partner chickenroad-game.cz official website Chicken Road game in Czech Republic, said. “Hráči říkají, že chicken road 2 hra https://chickenroad-game.cz/ je zábavná a přehledná.” Our partner chickengamecasino.sk official website Chicken Game casino in Slovakia, said. “Používatelia uvádzajú, že chickengamecasino.sk https://chickengamecasino.sk/ ponúka príjemné hranie.”
