Home › Forums › Product Discussion & Questions › BeoSound › Beosound 9000 – stop playing CD after 30 secs or so
- This topic has 2 replies, 2 voices, and was last updated 2 years, 1 month ago by
Stephen.
19 January 2024 at 01:06 #52276
BngOFan24
BRONZE MemberHi All,
I have a Beosound 9000 Mk1 that is pretty much fully ‘functional’ but when I play CDs it starts playing as normal but after 30 secs to a minute it stops playing, the CD and everything continues splining as normal but the sound stops coming from both speakers. When I play music from the Aux channel e.g. through Sonos Connect it works as normal.It a bizzare issue, any idea of what is the issue? Have any of you encountered this issue before? Thanks in advance.
19 January 2024 at 01:16 #52277BngOFan24
BRONZE MemberSee attached video
19 January 2024 at 12:02 #52278Stephen
BRONZE MemberMy 9000 is nearly 25 years-old and is on its third CD carriage / laser reader. Having said that, it was in use almost constantly until I bought a Beosound Moment about 9 years ago. I still use the 9000 though and encounter the same issue as you from time to time. With me, it goes to ‘pause’ mode, as if it sees an error on a CD. Usually this is fixed simply by removing the CD and blowing on it to remove any dust or by wiping it with a soft cloth. If it happens with every CD, it’s possible that the laser reader on your 9000 needs a clean. I think you can buy CDs with a small brush on them that can clean the laser. Sometimes, the laser might also need to be realigned, in which case, you need to take it to a B&O dealer. Good luck!
